Batterij
1 Antwoord 0 Score |
Mijn homebutton en touch id werkt niet meer na schermreparatie |
Microfoon werkt niet na schermvervanging |
Zwarte plakkertje bij oor flex cable beschadigd, kan ik deze bestellen |
Kan je een moederbord vervangen op je kapotte iPhone uitleg? Dankje |
Onderdelen
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Modellen
A1864 Verizon/Sprint/China, A1897 AT&T/T-Mobile/Global, A1898 Japan
Background
The successor to the iPhone 7 Plus, the iPhone 8 Plus (as well as the 8 and X) was formally announced by Apple on September 12, 2017. New features include a new hexa-core system-on-chip with improved system and graphics performance, a new glass back, and wireless charging using the Qi standard.
Identification
You can identify the iPhone 8 Plus by finding one of the model numbers either on the inner edge of the SIM card tray or within the phone's Settings app:
- A1863
- A1897
- A1898
You can find the model number through the phone's UI by going to the Settings app and navigating to General > About. Tap on the number listed in the Model Number section and it should change to a format that looks like the numbers above.
The iPhone 8 Plus features a 5.5 in (diagonal) glass screen with curved edges, a white or black bezel, and a home button. The back cover is glass and the edge frame is made from curved aluminum which can be colored grey, silver, or gold.
Volume controls can be found on the left edge while the power button and SIM card tray are situated on the right. A double camera "bump" is horizontally oriented and protrudes slightly from the back case.
The iPhone 8 Plus can be differentiated from the iPhone 8 by its bigger screen measuring 5.5 in diagonally (relative to the 4.7 in screen of the standard model).
Specifications
Announce date: September 12, 2017
Model: A1864, A1897
Developer: Apple Inc.
Operating System: iOS 11
Display (Retina HD Display with 3D Touch):
- 5.5 in (139.7 mm) LED-backlit widescreen
- Multi‑touch display with IPS technology
- 1920-by-1080-pixel resolution at 401 ppi
- True Tone display
- Wide color display (P3)
- 3D Touch
- 625 cd/m2 max brightness (typical)
- Dual-domain pixels for wide viewing angles
- Fingerprint-resistant oleophobic coating
- Support for display of multiple languages and characters simultaneously
- Display Zoom
- Reachability
Splash, Water, and Dust Resistant: Rated IP67 under IEC standard 60529
Camera: Contains both front and rear facing cameras.
- Two rear-facing cameras
- 12-megapixel wide-angle camera with ƒ/1.8 aperture
- 12-megapixel telephoto camera with ƒ/2.8 aperture
- Digital zoom up to 10x
- Optical Zoom at 2x
- Optical image stabilization
- Six-element lens
- Quad-LED True Tone flash
- Panorama (up to 63 megapixels)
- Sapphire crystal lens cover
- Backside illumination sensor
- Hybrid IR Filter
- Autofocus with Focus Pixels
- Tap to focus with Focus Pixels
- Live Photos with stabilization
- Wide color capture for photos and Live Photos
- Improved local tone mapping
- Body and face detection
- Exposure Control
- Noise reduction
- Auto HDR for photos
- Auto image stabilization
- Burst mode
- Timer mode
- Photo geotagging
- Front-facing Facetime camera
- 7-megapixel photos
- 1080p HD video recording
- Retina Flash
- ƒ/2.2 aperture
- Auto HDR
- Body and Face detection
- Burst mode
- Exposure control
- Timer mode
- Video Recording
- 4K video recording at 60fps
- 1080p HD video recording at 30fps or 60fps
- 720p HD video recording at 30fps
- Optical image stabilization for video
- Optical zoom at 2x
- Quad-LED True Tone Flash
- Slo-mo video support for 1080p at 120fps or 240fps
- Time-lapse video with stabilization
- Cinematic video stabilization (1080p and 720p)
- Continuous autofocus video
- Noise reduction
- Take 8-megapixel still photos while recording 4K video
- Playback zoom
- Video Geotagging
- Video formats recorded: HEVC and H.264
Touch ID: Fingerprint sensor built into the new Home button
Processor: Apple A11 chip with 64 bit architecture and embedded M11 motion coprocessor
RAM:
Storage: 64, 256 GB Flash Memory
Sensors:
- Touch ID fingerprint sensor
- Barometer
- Three-axis gyro
- Accelerometer
- Proximity sensor
- Ambient light sensor
Wireless Connectivity:
- Integrated 802.11 a/b/g/n/ac Wi-Fi with MIMO
- Bluetooth 5.0
- NFC
- GSM, CDMA, 3G, EVDO, HSPA+, LTE
- Digital Compass
- Assisted GPS and GLONASS
Dimensions: : 6.24 x 3.07 x 0.30 in (158.4 x 78.1 x 7.5 mm)
Weight: 202 g (7.13 oz)
Colors: Gold, Silver, Space Gray
Troubleshooting
- Diagnose any issues you may be having with your iPhone 8 using our iPhone 8 Plus Troubleshooting Page.
- Diagnose and repair screen backlight issues with our iDevice Backlight Troubleshooting Page.
Wallpaper
Want to see inside your iPhone without taking it apart? Check out our iPhone 8 Plus internals wallpaper and X-ray wallpaper!
