Batterij
1 Antwoord 0 Score |
Levertijd nederland pro tech toolkit |
mon flash led ne marche plus |
Luidspreker, slecht contact & Microfoon kapot. |
2 Antwoorden 0 Score |
2dehands toestel is geblokeerd |
Onderdelen
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Modellen
A1453 CDMA US/Japan, A1457 UK/Europe/Middle East, A1518 China Mobile, A1528 China Unicom, A1530 Asia Pacific, A1533 CDMA China Telecom, A1533 CDMA Verizon, A1533 GSM/North America
Wallpapers
Want to see the inside of your phone without opening it up? Check out our see-through iPhone 5s wallpaper.
Background
The iPhone 5s is part of the iPhone line, succeeding the iPhone 5. Apple held an event to formally introduce the phone (and its mid-range counterpart, the iPhone 5c) on September 10, 2013.
Similar to the iPhone 4s, the 5s is a revised version of its predecessor, the iPhone 5, but also incorporates a 64-bit Apple A7 processor, a built-in fingerprint sensor on its updated home button, and runs on the iOS 7 operating system.
Repair of this device is similar to the previous models, and requires screwdrivers and prying tools.
Identification
You can identify the iPhone 5s by one of the following model numbers etched into the back case:
- A1453
- A1457
- A1518
- A1528
- A1530
- A1533
The iPhone 5s features a flat glass front with black or white bezels. The back is made from space grey (black bezels), silver (white bezels), or gold (white bezels) anodized aluminum with two glass panels on the top and bottom matching the color of the front bezels. The edges are flat. A SIM tray is situated on the right side, with volume buttons on the left and the wake button up top. An AUX port is located on the bottom beside a lightning charging port.
You can tell it apart from the iPhone 5 by looking at the flash module to the right of the back camera. The 5 will have a circular flash module while the 5s has an oval flash.
iPhone 5 Flash Module | iPhone 5s Flash Module |
Specifications
Announce date: September 10, 2013
Model: A1533, A1453, A1457, A1528, A1530, A1518
Developer: Apple Inc.
Operating System: iOS 7 - iOS 12.5.6
Display (Retina Display):
- 4 in (102 mm)
- Multitouch widescreen
- 640 x 1136 pixel resolution at 326 ppi
- 800:1 contrast ratio
- LED backlit IPS TFT LCD
- Fingerprint resistant oleophobic coating on front
Fingerprint reader: Touch ID fingerprint reader
Camera: Contains both front and rear facing cameras.
- Front Camera
- Portrait photos at 1.2 MP
- VGA (720p) at 30fps
- Support for FaceTime over cellular wireless
- Rear Camera
- 8 MP
- HD Video (1080p) at 30fps
- Dual warm/LED Flashes
- IR filter
- Facial recognition / image stabilization
- Panorama photo
- Photo while recording video
Processor: Apple A7
RAM: 1 GB LPDDR3 RAM
Storage: 16, 32, and 64 GB flash memory
Wireless Connectivity:
- Integrated 802.11 a/b/g/n (Dual band 2.4 GHz and 5 GHz)
- Bluetooth 4.0
- GSM, CDMA, 3G, EVDO, HSPA+, LTE
- Digital Compass
- GPS and GLONASS signal reception
Dimensions: 4.87 × 2.31 × 0.30 in (123.8 × 58.6 × 7.6 mm)
Weight: 112 g (4.0 oz)
Colors: Space Gray, Silver, and Gold
Troubleshooting
- Diagnose any issues you may be having with your iPhone 5s using our iPhone 5s Troubleshooting Guide.
- Diagnose and repair screen backlight issues with our iDevice Backlight Troubleshooting Page.
