Batterij
1 Antwoord 0 Score |
Kun je alleen de backcover vervangen? |
1 Antwoord 1 Score |
TrueDepth camera not working after water damage, any hope? |
3 Antwoorden 0 Score |
Will face ID still work after screen swap |
2 Antwoorden 1 Score |
Missing Sensor(s): TG0B and TG0V |
Documenten
Onderdelen
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Modellen
A2176 US, A2398 Canada/Japan, A2399 Global, A2400 China
Wallpapers
We’ve got X-ray and internal teardown wallpapers for iPhone 12 mini. Check them out!
Background
A miniaturized version of the iPhone 12, the iPhone 12 mini includes most of the same specs, just squeezed into a smaller package. The mini, along with the rest of the iPhone 12 lineup, is now more angular with smaller bezels and features 5G and a magnetic “MagSafe” charging system. The iPhone 12 mini has a 5.4-inch “Super Retina XDR“ OLED—compared to the iPhone 12’s 6.1-inch display. It also ships with a lightning to USB-C cable, but no power adapter or EarPods. Black, white, (Product) Red, green, and blue color options are available.
Identification
You can identify the iPhone 12 mini by finding one of the model numbers either on the inner edge of the SIM card tray or within the phone's Settings app:
- A2176
- A2398
- A2399
- A2400
You can find the model number through the phone's UI by going to the Settings app and navigating to General > About. Tap on the number listed in the Model Number section and it should change to a format that looks like the numbers above.
The iPhone 12 mini features a 5.4 in (diagonal) flat glass screen, thin black bezels, and a notch at the top of the screen to accommodate a speaker and selfie camera. The back cover is glass and the edge frame is made from flat anodized aluminum.
Volume controls and the SIM tray can be found on the left edge while the power button is situated on the right. A rectangular camera "bump" containing two vertically-aligned cameras protrudes slightly from the back case. This model has no home button.
The iPhone 12 mini can be differentiated from the iPhone 12 by the mini's smaller 5.4 in screen relative to the 6.1 in screen of the iPhone 12.
Specifications
Announce date: October 13, 2020
Operating System: iOS 14
Display:
- 5.4-inch “Super Retina XDR” OLED
- Ceramic Shield glass technology
- Multi‑touch
- Haptic Touch
- 2340 × 1080 pixel resolution (476 ppi)
- 2,000,000:1 contrast ratio (typical)
- True Tone
- P3 wide color gamut
- 625 nits max brightness; 1200 nits max HDR (typical)
- Fingerprint-resistant oleophobic coating
Double primary camera:
- True Tone flash with Slow Sync
- 4K video recording up to 60 fps
- Wide-angle module (2x optical zoom in)
- 12 MP
- ƒ/1.6 aperture
- Optical image stabilization (OIS)
- Autofocus with 100% Focus Pixels
- Seven-element lens
- Ultra-wide module (120° field of view, 2x optical zoom out)
- 12 MP
- ƒ/2.4 aperture
- Five-element lens
TrueDepth selfie camera with Face ID:
- 12 MP
- ƒ/2.2 aperture
- 4K video recording, up to 60 fps
- Retina Flash
Processor: A14 Bionic with Neural Engine
- 5 nm process
- 6-core CPU
- 4-core GPU
RAM: 4 GB
Storage: 64, 128, or 256 GB
Sensors:
- Face ID
- Barometer
- Three-axis gyro
- Accelerometer
- Proximity sensor
- Ambient light sensor
Wireless Connectivity:
- 802.11ax Wi‑Fi 6 with 2x2 MIMO
- 5G (sub-6 GHz and mmWave)
- Gigabit LTE with 4x4 MIMO and LAA
- Bluetooth 5.0
- Apple-designed U1 Ultra Wideband chip for spatial awareness
- NFC
Dimensions: 5.18 × 2.53 × 0.29 in (131.5 × 64.2 × 7.4 mm)
Weight: 133 g (4.69 oz), 135 grams (4.76 oz) mmWave model
Water Resistance: IP68
Colors: Black, White, (Product) Red, Green, and Blue
Additional Information
- Official Tech Specs
- Wikipedia: iPhone 12 mini
