Battery
1 Antwoord 1 Score |
Welke I pad heb ik |
Device won't turn on, won't restore and won't update [4013 error] |
5 Antwoorden 6 Score |
The big one, is the Air 1 digitizer cross-compatible? |
4 Antwoorden 0 Score |
unable to activate touch id on this iPad after screen replacement |
Onderdelen
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Modellen
A1822
Background and Identification
The iPad 5th Gen 2017 is the successor to the iPad Air lineup, but shares more design features with the Air 1 than the Air 2, most notably, the inclusion of a non-fused display, an identical size and weight, and a 32.4 Wh battery. This unit is slightly deeper than the Air 2, measuring in at 7.5mm, up from 6.1mm on the iPad Air 2, and 32 g heavier. The 2017 model does inherit the Air 2's 8MP iSight camera and three finish options: Silver, Gold, and Space Gray.
Technical Specifications
Platform
- A9 chip with 64-bit architecture
- Embedded M9 coprocessor
Capacity
- 32GB
- 128GB
Size and Weight
- Height: 9.4 inches (240 mm)
- Width: 6.6 inches (169.5 mm)
- Depth: 0.29 inch (7.5 mm)
- Weight: 1.03 pounds (469 g)
Buttons and Connectors
- Home/Touch ID sensor
- Built‑in stereo speakers
- Lightning connector
- 3.5 mm headphone jack
- On/Off - Sleep/Wake
- Volume up/down
- Nano-SIM tray (cellular models)
Display
- Retina display
- 9.7-inch (diagonal) LED-backlit Multi-Touch display with IPS technology
- 2048-by-1536-pixel resolution at 264 ppi
- Fingerprint-resistant oleophobic coating
Camera
- 8-megapixel camera
- Panorama (up to 43 megapixels)
- HDR for photos
- Exposure control
- ƒ/2.4 aperture
- Five-element lens
- Hybrid IR filter
- Backside illumination
Video Recording
- 1080p HD video recording (30 fps)
- Slo‑mo (120 fps)
- 3x video zoom
FaceTime HD Camera
- 1.2-megapixel photos
- ƒ/2.2 aperture
- 720p HD video recording
Connectivity
- Wi‑Fi (802.11a/b/g/n/ac); dual band (2.4GHz and 5GHz); HT80 with MIMO
- Bluetooth 4.2 technology
Location
- Digital compass
- Wi-Fi
- iBeacon microlocation
Sensors
- Touch ID
- Three-axis gyro
- Accelerometer
- Barometer
- Ambient light sensor
- Touch ID
- Fingerprint identity sensor built into the Home button
Power and Battery
- Built-in 32.4-watt-hour rechargeable lithium-polymer battery
- Up to 10 hours of surfing the web on Wi-Fi, watching video, or listening to music
- Charging via power adapter or USB to computer system
