AC Inlet
1 Antwoord 0 Score |
Kan de oude monitor hergebruikt worden? |
7 Antwoorden 0 Score |
iMac 24" A1200 power supply pinout? |
2 Antwoorden 0 Score |
iMac 24'' won't turn on |
17 Antwoorden 6 Score |
Overheating causing graphic issues |
Onderdelen
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Modellen
2.16 GHz (iMac6,1), 2.33 GHz (iMac6,1)
Troubleshooting
There are no troubleshooting guides for the iMac Intel 24" EMC 2111 at this time.
Upgrades
You can cost-effectively upgrade a number of components in the iMac Intel 24" EMC 2118.
- Memory: The iMac Intel 24” EMC 2111 shipped with 1 GB (2x512 MB) of RAM. If your iMac is still running with only the stock RAM, upgrading will provide a dramatic performance boost at minimal cost. Upgrading to the maximum of 3 GB (1x1 GB, 1x2 GB) for EMC 2210) can be done very easily.
- Hard Drive: 250 GB hard drives came standard with the iMac Intel 24” EMC 2111. You can upgrade the drive up to 2 TB.
Identification and Background
You can verify that you have a iMac Intel 24” EMC 2111 by checking the processor information through "About This Mac" in the Apple menu.
Use the iMac identification system to help you identify your machine. iMacs tend to look very similar, and it's important to know which machine you have before ordering any replacement parts.
The first Intel based iMacs were released early 2006 and were the first Macintosh computers powered by an Intel processor, the Core Duo.
The 24" iMac was introduced in Late 2006. The plastic case iMacs of this generation are the most difficult iMacs to service due to their front bezel design.
