Battery
1 Antwoord 0 Score |
Phone stopped working in the middle of use |
1 Antwoord 1 Score |
Why is my phone not turning on? |
2 Antwoorden 0 Score |
Where can I find the original operating system |
Why isn't my phone charging? |
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Background
Samsung Galaxy S II T-989, also known as the Samsung Hercules or the Samsung SGH-T989, was released in October of 2011.
The device weighs 135 g (4.67 oz) and has dimensions of 129.8 x 68.8 x 9.4 mm (5.11 x 2.71 x 0.37 in). To see additional specifications for this device, go to the Samsung Galaxy S II T989 Full Specifications link under the Additional Information section.
Identification
The outer appearance of the phone features a T-Mobile brand name, written below the front speaker, and four touchscreen buttons along the bottom of the phone. The main difference between this model of the Galaxy SII, compared to Verizon of AT&T's version, is the camera on the back is vertically aligned. It comes in titanium and white color options.
Though the phone can be identified by the name Galaxy S II, on the back case you'll have to look at the original packaging or turn the phone on to find the model number. To find the model number of the S8 Active, go to Settings→ About phone.
Technical Specifications
- Dimensions: 129.8 x 68.8 x 9.4 mm (5.11 x 2.71 x 0.37 in)
- Weight: 135 g (4.76 oz)
- SIM: Mini-SIM
- Display: Super AMOLED Plus
- Size: 4.52 inches, 58.2 cm2 (~65.1% screen-to-body ratio)
- Resolution: 480 x 800 pixels, 5:3 ratio (~206 ppi density)
- OS: Android 2.3.5 (Gingerbread), upgradable to 4.1.2 (Jelly Bean)
- Chipset: Qualcomm APQ8060 Snapdragon S3
- CPU: Dual-core 1.5 GHz Scorpion
- GPU: Adreno 220
- Card Slot: microSDHC (dedicated slot), 8 GB included
- Internal: 16GB 1GB RAM, 32GB 1GB RAM
- Main Camera: 8 MP, AF
- Video: 1080p@30fps
- Selfie Camera: 2 MP
- WLAN: Wi-Fi 802.11 a/b/g/n, dual-band, Wi-Fi Direct, DLNA, hotspot
- Bluetooth: 3.0, A2DP, aptX
- Positioning: GPS, A-GPS
- USB: microUSB 2.0 (MHL TV-out), OTG
- Sensors: IAccelerometer, gyro, proximity, compass
- Battery: Removable Li-Ion 1850 mAh battery
Samsung Galaxy S II T989 User Manual
