Battery
1 Antwoord 1 Score |
Which screws does MSI gs63 use? |
2 Antwoorden 2 Score |
need to factory reset but it wont let me |
3 Antwoorden 0 Score |
How do I lubricate my CPU fan? |
1 Antwoord 0 Score |
My pc is running but nothing shows! |
Onderdelen
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Modellen
MSI GS63VR 7RF
Troubleshooting
For more information and help check out the MSI GS63VR 7RF Stealth Pro Troubleshooting page.
Background
The MSI GS63VR 7RF Stealth Pro is a new gaming laptop from 2017. It has a 7th generation Intel Core i7 processor and a GTX 1060 GPU. Dimensions (WxDxH)mm 380 x 249 x 17.7 mm (15 x 9.8 x .7)in, and weighs 1.8 kg (4 lbs). Is the successor to the 6th Generation and is succeeded by the GS73VR Stealth Pro. Runs on a Windows 10 OS system. Has a 15.6" FHD display that runs at (1920x1080p). It also has a front facing webcam with a rainbow back lit mechanical keyboard. A LAN port, is Wi-Fi and Bluetooth capable, 5x USB ports, 1x SD card reader, 1x HDMI port, 1x Mini-Display port, 2x speakers above the keyboard, a Mic-in port, and a headphone port. Model No: MS-16K2
- Memory Type: DDR4-2400
- 2x DIMM Slots
- 256GB SSD
- 1T HDD 2.5"
- A 3-cell Li-Polymer Battery
Identification
To help identify if this is your laptop, look at the sticker on the inside of the device when you first open it. On the bottom cover, look at the Model Number and see if it says MS-16K2.
