Full Case
2 Antwoorden 1 Score |
Why is my external hard drive making this weird noise & not showing up |
3 Antwoorden 3 Score |
Can HDDs operate upside down? |
1 Antwoord 1 Score |
Hdd is not getting detected |
6 Antwoorden 3 Score |
Suddenly I can't save files on my external hard drive anymore! |
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Background and Identification
A hard disk drive (HDD), hard disk, hard drive, or fixed disk is an electromechanical data storage device that uses magnetic storage to store and recall digital data using rapidly rotating plates coated with magnetic material. The plates are paired with magnetic hears that are usually arranged on a moving actuator arm and are designed to read and write data to the plate surfaces. Stored data is accessed in a random-accessed manner, meaning that blocks of data can be stored and recalled in any order. Hard drives retain stored data even when powered off, making them a type of non-volatile storage.
Hard drives were introduced by IBM in 1956 as the dominant secondary storage device for computers. Hard drives became the main storage devices for servers and personal computers, as well, though personal computers produced en masse, like tablets and cell phones, rely on flash products. Historically, over 224 companies have produced hard drives.
Solid-state drives (SSDs) are also used for data storage but feature higher data-transfer rates, better reliability, higher areal storage, and lower latency and access times.
Hard drives are often characterized by capacity and performance. Capacity is generally specified with unit prefixes corresponding to powers of 1,000. For instance, a 1-terabyte (TB) hard drive has a capacity of 1,000 gigabytes (GB, where 1 gigabyte is equal to 1 billion bytes). Performance is specified by the time required to move the device’s heads to a track, or the average access time, and the data transmission rate.
