GoPro Hero4 Session Teardown
3 Antwoorden 0 Score |
Can you replace the battery? |
1 Antwoord 1 Score |
How do I get a jammed sd card out |
1 Antwoord 0 Score |
How to repair a blank display screen? |
Back plate falling off |
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Background and Identification
The Hero4 Session (model no. CHDHS-101), released in July 2015, is the first waterproof action camera from GoPro. The device features a hard-plastic shell that eliminates the need for a larger outer casing. However, this waterproofing comes with a cost—unlike previous devices in the GoPro lineup, the Hero4 Session does not have a user-replaceable battery. Other notable changes include a new, cubed design, and a dual-microphone setup that reduces pops and clipping.
Technical Specifications
Resoluion
- Video: 1440p30, 1080p60, 720p100, 480p120
- Photo: 8MP
Audio Recording
- Features dual mono microphones
- Format: 32kHz sampling rate, AAC compression
Connectivity
- Micro-USB
- microSD slot
- Wi-Fi
- Bluetooth
More Specs
- Battery :Rated at 1030mAH, 3.8V, 3.23Wh
- Mass: 74g
