CD-station
3 Antwoorden 2 Score |
My PC doesn't display the bios screen and boots straight into Windows |
4 Antwoorden 4 Score |
No display, no post, no bios |
6 Antwoorden 2 Score |
Computer crash then no signal on monitor |
2 Antwoorden 3 Score |
No display 3 beep error |
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Background
A typical desktop PC is any PC that resides in a single location and does not have user interface components built within the system, such as a keyboard, mouse, or monitor. This does not include any laptops or all-in-one PCs.
Desktop PCs are commonly enclosed in cases known as "towers," which are generally rectangular boxes that are taller than they are wide. The weight of a desktop PC can range from 5 to 50 lbs depending on the components inside and depending on the material and size of its case.
The core components of a desktop PC include a power supply unit, a motherboard, a central processing unit (CPU), a graphical processing unit (GPU), RAM (Random Access Memory), and a hard drive.
Identification
If you have a prebuilt PC, navigate to System Information in Settings in order to determine model name and number.
