How to repair the Apple MagSafe2 Power Adapter with a Damaged Wire
1 Antwoord 1 Score |
Check if work with multimeter |
4 Antwoorden 5 Score |
How to disassembly MagSafe 2 T connector to fix pins springs? |
3 Antwoorden 1 Score |
Is there a known Mag-Safe II to Mag-Safe III adapter available yet |
2 Antwoorden 0 Score |
Magsafe 2 60w: How to identify power connections on board? |
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Background and Identification
MagSafe 2 features a magnetic connector with a slightly thinner profile, with a cord that sticks straight out from the MacBook in a "T" shape (as opposed to the 90-degree "L" shaped design on the original MagSafe).
All MacBooks and MacBook Pro models can charge on any of the 60 watt or 85 watt AC adapters.
