5 pins Magsafe connector and cable
14 Antwoorden 15 Score |
Not charging, blinking green/orange light |
2 Antwoorden 4 Score |
Can I make MagSafe2 to MagSafe1 converter? |
3 Antwoorden 0 Score |
Tips needed on how to crack open my AC Adapters |
1 Antwoord 3 Score |
Is it normal to have white paste inside charger or something leaked? |
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Background and Identification
Apple's MacBook laptop charger is easily recognizable by its square shape and MagSafe magnetic charger end. The MagSafe apparatus is designed to prevent damage to the laptop if the cord is stepped on, in which case the charger simply unplugs from the laptop, rather than taking the computer with it.
All MacBooks and MacBook Pro models can charge on any of the 60 watt or 85 watt AC adapters. The MacBook Air, though, has a recessed charging port on its side that requires a special AC adapter that Apple released with a 90 degree bend in it.
