Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Vragen Bekijk alle
Why isn't the right side of my iPhone 4S touchscreen working?
I first noticed that the right side of my touch screen wasn't working while writing an SMS when I couldn't type the letter "P". It works in landscape mode but not portrait (because it is a different location on the phone.) It works to launch apps but if I need the very right side of the screen it doesn't work. (For example, jumping to a certain letter in contacts or moving an app from the 1st page to the 2nd.) There is no damage to the screen or water damage to the phone. Is there a part that needs to be replaced or a connection that needs to be checked? Thank you in advance for any help or advice you can give.
Keith
Is dit een goede vraag?
Score 19
8 opmerkingen
@keith i am having the same problem right now, i am using Iphone 4s, please tell me what did u do so that it came back to normal?
door
i have the same problem too :( i cant touch the very left side of the screen:( plkease help mo
door
@keith i am having same problem what you are facing but i am using iphone 5 please suggest me to fix it. my mail id lazard.mba@gmail.com. thanks in advance.
door
Having the same issue with iPad 2 right side of screen not responding and thus I can't join wifi networks as the 'Join' key or button is on the right! Wits end crap...
door
3 commentaren meer tonen
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
keith harris, usually when the touch screen does not work in a specific area, it is the digitizer that has failed. Of course you should always try a reset/ recover on your device first, if it is unsuccessful you will have to replace the front display assembly. Follow this guide for that, and the part is available right here as well as many other places. There are those that say you can separate the digitizer from the LCD, I personally have not had any success with it due to the lack of proper (expensive ) equipment for that task. Hope this helps, good luck.
iPhone 4S Screen Afbeelding
Product
iPhone 4S Screen
$34.99
Was dit antwoord nuttig?
Score 3
12 opmerkingen:
Thanks for your help. The screen works perfectly now. I had the network connection issue after everything was said and done but found the solution of switching the time and date in the answers section. Everything is working fine now. Thanks again
door
Can you please explain better what was the solution you followed step by step? PLEASE!
door
I'm having the same issue with the letter "P" I've changed the screen and still has the same issue. Weird. Something control the letter "P" or that area?
door
Tried multiple screens & done everything. Still, no letter "P".
door
Still no letter P... 50 screens. No letter P.
door
7 commentaren meer tonen
Well I had the same issue.dropped my iPhone 5 and thereafter a part of the the bottom screen became unresponsive.what I did was to apply a little pressure to those areas and it came back to life.hope it helps.
Voeg je antwoord toe
keith harris zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 26
Altijd: 120,257
